Trailer light issues
New Hamburg ont
What I Drive
2025 Palisade
I recently purchased a 2025 Palisade. I had the dealer install an OEM trailer hitch and wiring harness. The first few times I used the trailer all worked as it should. Now after about 3 months the tail light do not work anymore. I can get them to flash on once when I put lights from auto mode to the on position. Then they go off again. Brake lights and signals work as they should. Trailer has been checked out by a trailer sales place and all is fine. Trailer works normal with other vehicles. I even plugged the palisade into one of their new trailers and the tail lights work normal. So from my older trailer (2011) to new they work different. My question is. Is there a relay or breaker that is popping when this happens. Not a fuse because all works normal otherwise.
Thanks
Paul
